查看: 255|回复: 0
A10S-OLINUXINO-MICRO 单板机
发表于 2015-7-30 09:52:21 | 显示全部楼层 |阅读模式
A10S是全志新的处理器并且得到以太网和HDMI的支持。除A10S的基于Cortex-A8 频率为1GHz的板拥有512MB RAM+100MB的以太网+ USB主机/ USB-OTG+ SD卡+ SD-MMC卡+ HDMI被释放。它可以作为一个媒体中心,一般Android设备或通用Linux设备。FEATURES
  •  A10S Cortex-A8 processor at 1GHz, 3D Mali400 GPU, NEON
  •  512MB RAM
  •  USB High-speed host with power control and current limiter
  •  USB-OTG with power control and current limiter
  •  HDMI output with ESD protectors
  •  100MBit native Ethernet
  •  Audio Line-input
  •  Audio Headphones output
  •  UEXT connector
  •  LCD connector to work with 4.3, 7.0, 10.1" LCD modules from Olimex
  •  50 GPIOs on three GPIO connectors
  •  MicroSD card connector
  •  SD/MMC card connector
  •  DEBUG-UART connector for console debug with USB-SERIAL-CABLE-F
  •  STATUS LED
  •  Power LED
  •  2KB EEPROM for MAC address and other storage
  •  5 BUTTONS with ANDROID functionality + BOOT/REC and POWER buttons
  •  Microphone input on connector (not populated)
  •  Composite TV-output on connector (not populated)
  •  JTAG-DEBUG connector (not populated)
  •  UART1 connector (not populated)
  •  +5V input power supply, noise immune design
  •  4 mounting holes
  •  Dimensions: (4000 x 3200) mils ~ (101.6 x 81.28) mm
A10S-OLinuXino-MICRO Datasheet .pdf
144.45 KB, 下载次数: 0
GMT+8, 2024-11-25 10:41 , Processed in 0.116981 second(s), 16 queries , MemCache On.
