SBC8530单板计算机有着小尺寸,并使用POP(层叠封装)CPU /内存芯片接口1GHz DM3730的处理器, 512MBytes的NAND闪存和512MBytes的DDR SDRAM。板卡已经露出了不少接口,包括串口,USB,以太网,摄像头,音响,LCD,触摸屏,DVD-D,S-Video等等,还设有板载WiFi和蓝牙模块WG7310提升无线网络功能。在板的后部有一个TF卡插槽来扩展存储能力,以及一个扩展接口,让用户的开发推广。Package on Package POP CPU/Memory chip
- TI DM3730 DaVinci Digital Media Processor
- Up to 1-GHz ARM® Cortex™-A8 Core, also supports 300, 600, and 800-MHz operation
- Up to 800-MHz TMS320C64x+™ DSP Core, also supports 260, 520 and 660-MHz operation (DM3730 only)
- NEON™ SIMD Coprocessor
- POWERVR SGX™ Graphics Accelerator
- ARM: 32KB I-Cache; 32KB D-Cache; 256KB L2 Cache
- Onchip 32KB ROM and 64KB Shared SDRAM
- 512MByte DDR SDRAM, 32bit, 200MHz
- 512MByte NAND Flash, 16bit
Audio/Video
- S-VIDEO display interface
- DVI high-resolution image output port (HDMI interface, support 720p, 30fps signal)
- Audio input interface
- Two-channel audio output interface
- TFT LCD interface, 24-bit true color, resolution supporting up to 2048*2048
- 4-line Touch Screen interface
- Camera interface (30-pin FPC connector, supports CCD or CMOS camera)
Data Transfer Interface
- 1 x 5 line Debug serial port, RS232 (DB9 connector)
- USB port:
- 1 x USB2.0 OTG, High-speed, 480Mbps (can only be configured as USB Device)
- 4 x USB2.0 Host, High-speed, 480Mbps
- TF card slot (on the rear of the board)
- Ethernet: 10/100Mbps, RJ45 connector
- WiFi/Bluetooth Module (WG7310)
Input Interface and Other Facilities
- One RESET button
- Two USER buttons (Defined as MENU and BACK in Android system)
- One expansion connector (2.0mm 40-pin SMT Female Pin Header, on the rear of the board)
- 1 x 5 line serial port, TTL voltage
- 1 x 3 line serial port, TTL voltage
- 1 channel McSPI Interface (Multichannel Serial Port Interface)
- 1 channel McBSP interface (Multi-Channel Buffered Serial Port)
- 1 channel I2C interface
- 1 channel HDQ interface (HDQ/1-Wire)
Mechanical Parameters
- Dimensions: 86 mm x 86 mm
- Input Voltage: +5V
- Power Consumption: 5V@0.31A (working without LCD)
- Working Temp.: 0 ℃ ~ 70 ℃
- Humidity Range: 20% ~ 90%
