查看: 343|回复: 0
ZMOTION 微控制器开发套件
发表于 2015-7-31 08:44:22 | 显示全部楼层 |阅读模式
Zilog公司的ZMOTION™检测控制的产品系列是一系列高性能的微控制器集成了运动检测算法结合精选的镜头和被动红外(PIR)传感器,以适应广泛的应用需求。提供给每个镜头/传感器组合,确保最佳的性能,同时降低显著开发风险和减少产品上市时间为ZMOTION™MCU优化的配置参数。Feature:
  • Optimized assemblage of MCU, Lens, and PIR Sensor
  •  High-performance eZ8® MCU core
  •  4 KB in-circuit programmable Flash available for application code
  •  Single-pin debug with unlimited breakpoints
  •  Internal precision oscillator running at 5.53 MHz
  •  External oscillator operating up to 20 MHz
  •  Sigma Delta ADC with up to 6 channels single ended or 3 channels differential available
  •  On-chip analog comparator with independent programmable reference voltage
  •  Full-duplex UART with dedicated BRG
  •  Two 16-bit timers with input capture, output compare, and PWM capability (11 modes total)
  •  Watchdog timer (WDT) with dedicated internal oscillator
  •  6 to 25 I/O pins depending upon package
  •  2.7 V to 3.6 V operating voltage with extended operating temperature range —400 C to +1050 C
  •  Enhanced PIR software engine controlled and monitored through software API registers
  •  Select from an assortment of lenses and pyroelectric sensors to best fit your application
  •  Optimized API settings provided for each lens and pyroelectric sensor combination
  •  Create your own API settings to match your own lens
  •  Directly supports 1 or 2 pyroelectric sensors
  •  Sensitivity control, range control, and directionality detection
  •  Hypersense detection mode for Occupancy sensing
  •  Low power modes
ZMOTION Datasheet.pdf
205.33 KB, 下载次数: 0
ZMOTIO Quick Start Guide.pdf
155.37 KB, 下载次数: 0
GMT+8, 2024-11-25 10:29 , Processed in 0.111457 second(s), 16 queries , MemCache On.
