查看: 308|回复: 0
BQ500410AEVM评估模块
  • 签到天数: 11 天
    发表于 2014-10-14 10:03:04 | 显示全部楼层 |阅读模式
    BQ500410AEVM评估模块是用于用于符合 Qi 的自由定位无线电源发送器管理器的评估模块 ,提供了所有主要功能用于评估bq500410A芯片应用在全功能WPC A6型无线发射机。The bq500410AEVM-085 evaluation module (EVM) provides all major functions for evaluation of the bq500410A IC in a fully functional WPC A6 type wireless transmitter. The bq500410A supports up to three co-located coils for increased free positioning area. Any Qi-compliant receiver or bq51013AEVM-764, -765 receivers EVM can be used for evaluation. The bq500410AEVM-085 is a 12V input design with optional on-board boost converter for 5V operation. Availability of the bq500410AEVM-085 is limited.
    特性
    • WPC-certified transmitter
    • Transmitter mounting pad to provide correct receiver interface
    • Receiver output up to 5 W
    • Standard A6-type transmitter coil
    • Option to configure an external buzzer
    GMT+8, 2025-1-15 17:34 , Processed in 0.108283 second(s), 15 queries , MemCache On.
