LPCXpresso™是一个恩智浦基于ARM的微控制器的低成本开发平台。该平台是由一个简化的Eclipse基于IDE和低成本的目标板,其中包括一个附加SWD调试器。 LPCXpresso是一个终端到终端的解决方案,使嵌入式工程师开发从最初评估他们的应用程序到最终生产。特性
- LPC4337 dual-core (M4F and M0+) MCU running at up to 208 MHz
- On-board high-speed USB based debug probe with CMSIS-DAP and LPCXpresso IDE Redlink protocol options, can debug the on-board LPC4337 or external target
- Support for external debug probes
- Tri-color LED
- Target Reset, ISP and WAKE buttons
- Expansion options based on Arduino UNO R3 and Pmod™, plus additional expansion port pins
- On-board Ethernet PHY (output available at expansion connectors)
- High speed USB A/B connector for host or slave operation
- 8 Mb Macronix quad SPI flash
- UART, I²C and SPI port bridging from LPC4337 target to USB via the on-board debug probe
- FTDI UART connector
