查看: 273|回复: 0
STM8S 恒温控制器开发板
发表于 2015-8-11 10:16:47 | 显示全部楼层 |阅读模式
STEVAL-IHT001V2恒温套件提供了一个强大和低成本的ST解决方案(微控制器和交流开关)来控制冰箱,冰柜或冰箱/冰柜组合。基本的,化霜,和空气流通的版本是来解决中低端和中高端散热家电市场的配置。它允许一个单相感应电动机和一个灯泡的控制下,并任选地,融霜电阻和一个风扇,工作在220/240 VRMS,50/60赫兹电源电压。温控器套件是与运营100/120 V RMS50/60赫兹但供应电容值必须进行修改。Features
  • Low-cost solution for spark-free thermostats:
  • No need for a sealed version
  • Low-cost STM8S microcontroller for thermostat control
  • Low-cost capacitive power supply
  • High efficiency:
  • Refrigerator consumption reduction by adjusting and reducing the hysteresis threshold of the temperature
  • Improved efficiency by turning on the defrost resistor only when it's useful and not at each OFF cycle of the compressor (as done in some mechanical thermostats)
  • High system immunity:
  • Overvoltage protected ACS switches: ACST610-8FP for compressor control, ACS110-7SN for defrost resistor and ACS102-6TA for light bulb and fan
  • Class A criteria for IEC 61000-4-4 up to above 3 kV levels
  • Flexibility:
  • Development: program setting with PC interface to change firmware variables
  • Industrialization: end-of-production MCU programming thanks to FLASH, for soft upgrade and efficient MCU stock management
  • RoHS compliant
STEVAL-IHT001V2 Datasheet.pdf
142.21 KB, 下载次数: 3
GMT+8, 2025-1-14 00:49 , Processed in 0.114089 second(s), 16 queries , MemCache On.
