查看: 232|回复: 0
AM3359 工业通信引擎
  • 签到天数: 11 天
    发表于 2014-9-17 13:57:58 | 显示全部楼层 |阅读模式
    AM3359 工业通信引擎是一个基于ARM Cortex-A8内核AM335X系列处理器的开发平台,主要应用于工业通信方面。The AM335x ARM Cortex-A8 Processors integrate the Programmable Real-time Unit (PRU) that has been architected to implement the real-time communication technologies used in a broad range of industrial automation equipment. It enables low foot print designs with minimal external components and with best in class low power performance.TMDSICE3359 is a revised version of TMDXICE3359 with production AM3359 silicon and a notable improvements including:
    • Option of controlling the Ethernet ports from PRU or from 2-port GbE switch
    • On-board OLED display
    • DDR3 memory
    • Support for larger NOR Flash upto 32Mb
    GMT+8, 2025-1-15 17:39 , Processed in 0.116547 second(s), 15 queries , MemCache On.
