查看: 387|回复: 0
AD8310评估板
发表于 2015-8-12 09:26:04 | 显示全部楼层 |阅读模式
       AD8310-EVALZ是一款配置齐全的4层FR4全功能评估板,设计用来帮助用户轻松评估AD8310的所有特性。它提供RF输入和VLOG输出SMA连接,并采用单端设置。需要时,RF输入可以选择采用全差分信号工作。将线夹引线连接到VPOS和COMM测试点,评估板就可以使用+5V/8 mA电源;电源电压范围为+2.7至+5.5V。
FEATURES
  • Multistage demodulating logarithmic amplifier
  • Voltage output, rise time <15 ns
  • High current capacity: 25 mA into grounded RL
  • 95 dB dynamic range: −91 dBV to +4 dBV
  • Single supply of 2.7 V min at 8 mA typ
  • DC to 440 MHz operation, ±0.4 dB linearity
  • Slope of +24 mV/dB, intercept of −108 dBV
  • Highly stable scaling over temperature
  • Fully differential dc-coupled signal path
  • 100 ns power-up time, 1 mA sleep current
AD8310 Datasheet.pdf
386.9 KB, 下载次数: 0
GMT+8, 2025-1-14 00:43 , Processed in 0.121484 second(s), 16 queries , MemCache On.
