查看: 428|回复: 0
E1仿真工具
  • 签到天数: 11 天
    发表于 2014-9-16 09:49:44 | 显示全部楼层 |阅读模式
    As a highly affordable on-chip debugging emulator for Renesas's mainstream MCUs, E1 provides all the basic debugging functions while serving as a flash programmer at the same time.For the communication system, serial, JTAG or LPD connection can be selected depending on the MCU type.In addition to the basic debugging functions, it incorporates Hot Plugin function that allows you to connect the E1 emulator without having to turn off the system, thus achieving efficient debugging and performance evaluation.
    GMT+8, 2025-1-15 17:19 , Processed in 0.105299 second(s), 15 queries , MemCache On.
