查看: 290|回复: 0
MultiLink HC08仿真工具
  • 签到天数: 11 天
    发表于 2014-9-12 14:16:52 | 显示全部楼层 |阅读模式
    MultiLink HC08仿真工具是一款使用简单,低功耗的开发工具,可用于开发Freescale 68HC08系列MCU。The MON08 Multilink is an easy-to-use, low-cost development tool for Freescale's 68HC08 flash MCUs. The MON08 Multilink provides in-circuit emulation, debugging and programming through the 68HC08's standard MON08 serial debug/breakpoint interface.
    特性
    Features that help make the MON08 Multilink a versatile, time-saving tool include the following:
    • Universal development tool for all MON08 68HC08s
    • Real-time in-circuit debug through MON08 interface
    • Fast in-circuit programming
    • Auto-detects baud rate and frequency
    • Provides optional overdrive clock to target
    • Small unobtrusive size (approx. 3" x 2" x 3/4")
    • Supports 2 to 5.5-volt 68HC08s
    • USB-to-MON08 interface
    • Automatically cycles power for security checks (up to 125 mA)
    GMT+8, 2025-1-28 10:53 , Processed in 0.107494 second(s), 15 queries , MemCache On.
