查看: 356|回复: 0
MCB1549 MCU开发套件
  • 签到天数: 11 天
    发表于 2014-9-12 14:05:41 | 显示全部楼层 |阅读模式
    MCB1549开发套件是针对您开发测试NXP LPC1500系列MCU功能的开发工具。The Keil MCB1549 Evaluation Board introduces you to the NXP LPC1500 family and allows you to create and test working programs for this advanced architecture.The MCB1549 Evaluation Board include MDK-ARM Evaluation Tools. These tools help you get started writing programs and testing the microcontroller and its capabilities. Many sample applications including several USB examples and quick start guide for the MCB1549 are included.特性
    • 72 MHz LPC1549 with Cortex-M3 processor in LQFP100 package
    • 36 KB On-Chip SRAM
    • 256 KB On-Chip Flash
    • On-Board Memory: 16 MB NOR Flash, 4 MB Quad-SPI Flash, 16 MB SDRAM, & 16 KB EEPROM (I²C)
    • Color QVGA TFT LCD with touchscreen
    • CAN interfaces
    • Serial/UART Port
    • MicroSD Card Interface
    • Digital Temperature Sensor (I²C)
    • Analog Voltage Control for ACD Input
    • Debug Interface Connectors:
      • 20-pin JTAG (0.1 inch)
      • 10-pin Cortex debug (0.05 inch)
      • 20-pin Cortex debug + ETM Trace (0.05 inch)
    • DAP connector
    • Full speed USB 2.0
    GMT+8, 2024-11-25 17:51 , Processed in 0.114144 second(s), 15 queries , MemCache On.
