查看: 244|回复: 0
Rayeager PX2 开发板
发表于 2015-8-14 16:40:58 | 显示全部楼层 |阅读模式
Rayeager PX2 1GB增强版在旧版的基础上增加外置天线接口,采用Rockchip PX2处理器,内置双核ARM Cortex-A9核心,内存1GB DDR3@400MHz,最高运行频率1.4GHz,配备Mali-400 MP4 GPU,支持OpenGL ES 1.1/2.0和OpenVG 1.1,同时支持ARM DS-5 Streamline性能分析工具,支持XBMC以及最新Android 4.4.2,LCD、VGA、HDMI,拥有95个扩展引脚,包括GPIO、I2Cx3、SPI、CIF、RGB、SARADC、HSADC、UART、PWMx2、TS等常见接口。MicroProcessor Feature:
  •  Dual-core ARM Cortex-A9 MPCore processor, a high-performance, low-power and cached application processor
  •  SCU ensures memory coherency between the two CPUs  Integrated 32KB L1 instruction cache , 32KB L1 data cache with 4-way set associative
  •  Trustzone technology support
  •  Superscalar, variable length, out-of-order pipeline with dynamic branch prediction, 8-stage pipeline
  •  Include VFPv3 hardware to support single and double-precision add, subtract, divide, multiply and accumulate, and square root operations
  •  4 separate power domain to support internal power switch and externally turn on/off based on different application scenario
    •  PD_A9_0: 1st Cortex-A9 + Neon + FPU + L1 I/D Cache
    •  PD_A9_1: 2nd Cortex-A9 + Neon + FPU + L1 I/D Cache
    •  PD_DBG: CoreSight-DK for Cortex-A9
    •  PD_SCU: SCU + L2 Cache controller
  •  Full coresight debug solution
    •  Debug and trace visibility of whole systems
    •  Invasive and non-invasive debug
    •  ETM trace support
  •  512KB unified L2 Cache
  •  Full implementation of the ARM architecture v7-A instruction set, ARM Neon Advanced SIMD (single instruction, multiple data) support for accelerated media and signal processing computation
  •  One isolated voltage domain to support DVFS
  •  Integrated timer and watchdog timer per CPU
Rockchip PX2 Datasheet.pdf
4.31 MB, 下载次数: 0
GMT+8, 2025-1-13 19:43 , Processed in 0.116695 second(s), 16 queries , MemCache On.
