查看: 1657|回复: 0
ATTINY85 开发板
发表于 2015-8-31 14:50:41 | 显示全部楼层 |阅读模式
Attiny85是一个有趣的处理器,因为尽管是如此之小,它具有闪存8K和5个I / O引脚,包括模拟输入和PWM'模拟'输出。我们设计了一个USB引导程序,所以你可以将其插入任何一台电脑,并重新写了一个USB端口,就像一个Arduino(它使用2的5个I / O引脚,让你有3)。事实上,我们甚至做了一些简单的修改到Arduino IDE,这样它的工作原理就像一个小型的植物。适合小型和简单的项目,GEMMA将是你去到可穿戴的电子平台。Feature:
  • Super small, only 1.1" / 28mm diameter and 0.28" / 7mm thick.
  •  Easy-to-sew or solder pads for embedding in your wearable project
  •  Low cost enough, you can use one for every weekend project
  •  ATtiny85 on-board, 8K of flash, 512 byte of SRAM, 512 bytes of EEPROM
  •  Internal oscillator runs at 8MHz
  •  Ultra low power, draws only 9 mA while running
  •  USB bootloader with a nice LED indicator looks just like a USBtinyISP so you can program it with the Arduino IDE (with a few simple config modifications)
  •  Mini-USB jack for power and/or USB uploading, you can put it in a box or tape it up and use any USB cable for when you want to reprogram.
  •  We really worked hard on the bootloader process to make it rugged and foolproof
  •  ~5.25K bytes available for use (2.75K taken for the bootloader)
  •  On-board 3.3V power regulator with 150mA output capability and ultra-low dropout. Up to 16V input, reverse-polarity protection, thermal and current-limit protection.
  •  Power with either USB or external output (such as a battery) - it'll automatically switch over
  •  On-board green power LED and red pin #1 LED
  •  Reset button for entering the bootloader or restarting the program.
  •  3 GPIO - The 3 independent IO pins have 1 analog input and 2 PWM output as well.
  •  Hardware I2C capability for breakout & sensor interfacing.
ATTINY85 Datasheet.pdf
634.12 KB, 下载次数: 0
GMT+8, 2025-1-13 19:43 , Processed in 0.107777 second(s), 16 queries , MemCache On.
