查看: 310|回复: 0
USB5537B 评估板
发表于 2015-9-6 10:18:26 | 显示全部楼层 |阅读模式
EVB-USB5537是消费评估板,采用了USB5537B7端口USB3.0/2.0集线器。该USB5537B集线器支持超SS,高速HS,全速FS和低速LS USB信号的所有定义的USB操作速度的完全覆盖。四下游端口USB3.0兼容和三个下游端口USB2.0兼容。该评估板支持外部的SMBus接头以及定制功能的2兆位SPI闪存设备。该评估板还提供板载SPI编程接口可选。Feature:
  •  USB5537B-60xx in a 72-pin QFN RoHS compliant package
  •  USB 3.0 compliant (SS, HS, FS, and LS operation)
  •  USB pins are 5 V tolerant
  •  Self-Powered operation
  •  Four downstream USB 2.0/3.0 ports
  •  Three additional downstream USB 2.0 ports
  •  All downstream ports support individual port power
  •  Downstream ports 1-4 support individual overcurrent sense
  •  Downstream ports 5-7 are configurable for individual overcurrent sense
  •  All downstream ports are battery charge enabled (2.5A max per port)
  •  Can support up to 5A downstream Port Power at any one time
  •  Supports Dynamic Battery Charge Enable/Disable
  •  Onboard SPI Flash for external downloadable firmware
  • Low-Cost, 4-layer space saving design
  •  Operates from a single voltage (+12.0V, regulated) external power supply
  •  Onboard 25 MHz crystal by default
  •  Onboard +5.25 V, 6 Amp regulator
  •  Onboard +3.3 V, 0.5 Amp regulator
  •  Onboard +1.25 V, 1 Amp regulator
  •  +3.3 V, Port Power and Reset LED indicators
  •  Battery Charge Enable, Dynamic Battery Charge and Port Disable LED indicators
  •  Port Removable LED indicators
  •  Supports SMBus interface
EVB-USB5537_E Evaluation Board User Manual.pdf
3.32 MB, 下载次数: 0
GMT+8, 2024-11-25 08:29 , Processed in 0.117588 second(s), 16 queries , MemCache On.
