查看: 834|回复: 0
ADAU1761 评估板
发表于 2015-9-7 11:00:29 | 显示全部楼层 |阅读模式
ADAU1761是一款低功耗,集成数字音频处理的立体声音频编解码器,支持立体声48 kHz的录音和回放,在14mW,采用1.8 V模拟电源。立体声音频ADC和DAC支持的采样率从8千赫到96千赫和数字音量控制。Feature
  • SigmaDSP 28-/56-bit, 50 MIPS digital audio processor
  • Fully programmable with SigmaStudio graphical tool
  • 24-bit stereo audio ADC and DAC: >98 dB SNR
  • Sampling rates from 8 kHz to 96 kHz
  • Low power: 7 mW record, 7 mW playback, 48 kHz at 1.8 V
  • 6 analog input pins, configurable for single-ended or differential inputs
  • Flexible analog input/output mixers
  • Stereo digital microphone input
  • Analog outputs: 2 differential stereo, 2 single-ended stereo, 1 mono headphone output driver
  • PLL supporting input clocks from 8 MHz to 27 MHz
  • Analog automatic level control (ALC)
  • Microphone bias reference voltage
  • Analog and digital I/O: 1.8 V to 3.65 V
  • I 2C and SPI control interfaces
  • Digital audio serial data I/O: stereo and time-division multiplexing (TDM) modes
  • Software-controllable clickless mute
  • Software power-down
  • GPIO pins for digital controls and outputs
  • 32-lead, 5 mm × 5 mm LFCSP
  • −40°C to +85°C operating temperature range
ADAU1761 Datesheet.pdf
833.64 KB, 下载次数: 1
GMT+8, 2024-11-25 08:28 , Processed in 0.102775 second(s), 16 queries , MemCache On.
