Rapid Module Evaluation: The boards allow the performance of the LR Series modules to be evaluated quickly in a user’s environment.
Range Testing: Using the on-board encoders and decoders to generate a simplex transmission, a pair of evaluation boards can be used to evaluate the range performance of the modules.
Design Benchmark: The boards provide a known benchmark against which the performance of a custom design may be judged.
Application Development: An onboard prototyping area allows for the development of custon circuits directly on the evaluation board. All signal lines are available on a header for easy access.
