飞兆半导体FIS1100评估套件是6D MEMS惯性测量单元(IMU)与传感器融合到指定的系统级定位精度。当使用随机提供的XKF39D传感器融合,该系统配有一个准确的±3°俯仰和横滚方向和一个±5°偏航/航向典型的规范。它集成了一个3轴陀螺仪和3轴加速度计,可以通过一个I2C主机连接外部±3轴磁力计,形成了完整的9DOF系统。Features
- FIS1100 6D Inertial Measurement Unit
- World's First Complete Consumer Inertial Measurement Unit (IMU) with Sensor Fusion Library to Specify Orientation Accuracy: ±3º Pitch and Roll, ±5º Yaw/Heading
- 3-Axis Gyroscope and 3-Axis Accelerometer in a Small 3.3x3.3x1mm LGA Package
- Integrated AttitudeEngine Motion Co-processor with Vector DSP PerformsSensor Fusion at 1kHz Sampling Rate, while Outputting Data to Host Processor at a Lower Rate - Improving Accuracy while Reducing Processor MIPS, Power, and Interrupt Requirements
- Complete System Solution for 3D Motion Tracking, Optimized 9D Sensor Fusion Library (XKF3) Featuring in-use Auto-Calibration Enabling Accurate 3D Orientation (quaternion) and High-Pass 3D Velocity Motion Tracking
- Large 1536 Byte FIFO can be used to Buffer 9DOF Sensor Data to Lower System Power Dissipation
- New Motion on Demand Technology for Polling Based Synchronization
- Large Dynamic Range from ±32dps to ±2,560dps and ±2g to ±8g
- Low Latency, High-Resolution OIS Mode
- Low Noise 50μg/√Hz Accelerometer and 10mdps/√Hz Gyroscope
- Low Power and Warm-Start Modes for Effective Power Management
- Digitally Programmable Sampling Rate and Filters
- Host Serial Interface Supporting I2C or SPI
- I2C Master for Interfacing External Magnetometer
- Embedded Temperature Sensor
- Wide Extended Operating Temperature Range (-40°C to 85°C)
- XKF3 9D Sensor Fusion Library
- Continuous Sensor Auto Calibration, No User Interaction Required
- Real-Time, Low-Latency Optimal estimate of 3D Orientation
- Best-in-Class Immunity to Magnetic Distortions
- Best-in-Class Immunity to Transient Accelerations
- Flexible use Scenarios, North Referenced, Unreferenced
- Extensive Status Reporting for Smooth Integration in Applications
- Optimized Library for Popular Microcontrollers
Applications
- Sport & Fitness Tracking
- Wearable and Health Monitoring
- Pedestrian Navigation
- Light Industrial, Robotics and Autonomous Machines
- Natural User Interfaces, Gaming, VR/AR
- GNSS Augmentation and Dead Reckoning
- Optical Video and Image Stabilization
