查看: 276|回复: 0
EVAL-ADXL001-250Z 评估板
发表于 2015-9-11 09:12:43 | 显示全部楼层 |阅读模式
亚德诺半导体 MEMS 加速度计能够精确进行运动 检测。亚德诺半导体出品的 MEMS 加速度计专门设计用于 在注重性能的应用中测量加速度、倾斜、冲击和振动 。亚德诺半导体的 MEMS 加速度计产品系列 在功率、噪声、带宽和温度规格方面处于业界领先地位。ADXL001是比前几代加速计提供高性能和高带宽的一大进步。本部分适用于工业,医疗和军事应用在需要宽带宽,小尺寸,低功耗和强大的性能是必不可少的。FEATURES
  • High performance accelerometer
    • ±70 g, ±250 g, and ±500 g wideband ranges available
    • 22 kHz resonant frequency structure
    • High linearity: 0.2% of full scale
    • Low noise: 4 mg/√Hz
  • Sensitive axis in the plane of the chip
  • Frequency response down to dc
  • Full differential signal processing
  • High resistance to EMI/RFI
  • Complete electromechanical self-test
  • Output ratiometric to supply
  • Velocity preservation during acceleration input overload
  • Low power consumption: 2.5 mA typical
  • 8-terminal, hermetic ceramic, LCC package
ADXL001 Datasheet.pdf
212.91 KB, 下载次数: 0
GMT+8, 2025-1-13 17:40 , Processed in 0.123617 second(s), 17 queries , MemCache On.
