查看: 344|回复: 0
RM48控制板
发表于 2015-9-15 09:27:06 | 显示全部楼层 |阅读模式
德州仪器RM48控制卡的理想产品最初的软件开发和短期构建系统原型,试验台和需要轻松获得高性能控制器的许多其他项目。控制卡是利用行业标准的DIMM封装来提供低截面单板控制器解决方案的完整板级模块。控制卡采用相同的100引脚连接器封装来提供模拟和数字I/ O板载控制器,并合理地互换。主机系统需要只提供单一5V电源轨的controlCARD的它的全部功能。控制卡可以用作一个电动机控制套件一部分,并提供额外的控制,连接和安全性评价的特性。特性
  • A Texas Instruments RM48L952 337-ball BGA microcontroller
  • On board USB XDS100v2 JTAG emulator
  • TI 14 pin JTAG debug header for alternate, external JTAG emulator
  • JTAG Isolation for either xds100 or alternate emulator
  • 10/100 Mbps Ethernet interface via RJ-45 with same PHY as on the TMDXRM48HDK
  • Hardware option for routing one or both N2HET timers to the DIMM interface
  • Isolated UART/SCI accessible through a USB Virtual Port (VCP)
  • LPO_TEST push button switch (causes CLKDET hardware fault on MCU)
  • LED indicators for xds100 power, activity, target/MCU power, HET pin activity, Ethernet link and activity, Ethernet speed, and nERROR.
  • Reset pushbuttons (nPOR and nRST)
  • 3V ADC input configuration
  • On board power supply supporting a 5V (as on the DRV8301 EVM) to 6V DC input and producing the 3.3V and 1.2V for the MCU
Hercules™ RM Microcontrollers.pdf
220.47 KB, 下载次数: 1
GMT+8, 2025-1-13 17:28 , Processed in 0.130799 second(s), 16 queries , MemCache On.
