查看: 217|回复: 0
CS4525演示套件
发表于 2015-9-18 09:32:12 | 显示全部楼层 |阅读模式
CS4525是一个立体声模拟或数字输入PWM高效率D类放大器的音频系统集成立体声模数(A/ D)转换器。立体声功率放大器可提供高达15 W的每通道8Ω扬声器从一个小的节省空间的48引脚QFN封装。在PWM放大器可实现大于85%的效率。封装发生热增强以获得最佳的散热其中省去了一个散热器。 Features
  •  Fully Integrated Power MOSFETs 
  • No Heatsink Required
    •  Programmable Power Foldback on Thermal Warning
    •  High Efficiency 
  • > 100 dB Dynamic Range 
  • < 0.1% THD+N @ 1 W 
  • Configurable Outputs (10% THD+N)
    •  1 x 30 W into 4 Ω, Parallel Full-Bridge
    •  2 x 15 W into 8 Ω, Full-Bridge
    •  2 x 7 W into 4 Ω, Half-Bridge + 1 x 15 W into 8 Ω, Full-Bridge 
  • Built-In Protection with Error Reporting
    • Overcurrent/Undervoltage/Thermal Overload Shutdown
    • Thermal Warning Reporting 
  • PWM Popguard® for Half-Bridge Mode 
  • Click-Free Start-Up 
  • Programmable Channel Delay for System Noise & Radiated Emissions Management
CS4525 Datasheet.pdf
1.27 MB, 下载次数: 0
GMT+8, 2025-1-13 17:46 , Processed in 0.119527 second(s), 16 queries , MemCache On.
