查看: 255|回复: 0
AS5040 磁传感器开发板
发表于 2015-9-18 09:56:09 | 显示全部楼层 |阅读模式
AS5040是一种非接触式磁旋转编码器进行精确的360°的整圈角度测量。它是系统级芯片,结合集成霍尔元件,模拟前端和数字信号处理在单个器件中。来测量角度,仅仅需要一个简单的2极磁体,旋转在芯片的中心,磁体可以放置上方或下方集成电路。这种绝对角度测量提供了磁铁的角位置,每转0.35度=1024的位置分辨率为即时指示。该数字数据可以作为一个串行比特流以及PWM信号。Key Features
  • ƒ Contactless high resolution rotational position encoding over a full turn of 360 degrees
  • ƒ Two digital 10bit absolute outputs:
    •  Serial interface and
    •  Pulse width modulated (PWM) output
  • ƒ Three incremental output modes:
    •  Quadrature A/B and Index output signal
    •  Step / Direction and Index output signal
    •  3-phase commutation for brushless DC motors
    •  10, 9, 8 or 7 bit user programmable resolution ƒ
  • User programmable zero / index position
  • ƒ Failure detection mode for magnet placement monitoring and loss of power supply ƒ
  • Rotational speeds up to 30,000 rpm ƒ
  • Push button functionality detects movement of magnet in Z-axis ƒ
  • Serial read-out of multiple interconnected AS5040 devices using Daisy Chain mode ƒ
  • Wide temperature range: - 40°C to + 125°C ƒ
  • Fully automotive qualified to AEC-Q100, grade 1 ƒ
  • Small Pb-free package: SSOP 16 (5.3mm x 6.2mm)
AS5040 Datesheet.pdf
1.07 MB, 下载次数: 0
GMT+8, 2025-1-13 17:29 , Processed in 0.115020 second(s), 16 queries , MemCache On.
