查看: 288|回复: 0
ADF70XXMBZ2 评估板
发表于 2015-9-21 09:51:03 | 显示全部楼层 |阅读模式
ADF7021是一款高性能,低功耗,高集成度的2FSK/3FSK/4FSK收发器。它的目的是在窄带,免授权的ISM频带进行操作,并在以80兆赫至650兆赫和862兆赫至950兆赫的频率范围的许可的频带。该器件具有高斯和上升余弦发送数据过滤选项,以提高频谱效率窄带应用。FEATURES
  • Low power, narrow-band transceiver
  • Frequency bands using dual VCO
    • 80 MHz to 650 MHz
    • 862 MHz to 950 MHz
  • Modulation schemes
    • 2FSK, 3FSK, 4FSK, MSK
  • Spectral shaping
    • Gaussian and raised cosine filtering
  • Data rates supported
    • 0.05 kbps to 32.8 kbps
  • 2.3 V to 3.6 V power supply
  • Programmable output power
    • 16 dBm to +13 dBm in 63 steps
  • Automatic PA ramp control
  • Receiver sensitivity
    • 130 dBm at 100 bps, 2FSK
    • 122 dBm at 1 kbps, 2FSK
    • 113 dBm at 25 kbps, raised cosine 2FSK
  • Patent pending, on-chip image rejection calibration
ADF7021 Datasheet.pdf
1.24 MB, 下载次数: 0
GMT+8, 2025-1-13 15:58 , Processed in 0.108385 second(s), 16 queries , MemCache On.
