查看: 244|回复: 0
C8051F70X开发套件
发表于 2015-8-26 09:19:07 | 显示全部楼层 |阅读模式
C8051F7xx系列高引脚数MCU为成本敏感,高I / O的嵌入式系统提供了一个专利待批的触摸感应功能,它是强大的,准确的,反应迅速,易于配置。提供多达54个通用I/ O引脚和一个25 MIPS8051 CPU,该C8051F7xx系列微控制器带来的处理能力和灵活的应用,如工业控制,安防系统,小区暖通,家电,键盘,现金水平高机和传真机/打印机/扫描仪前面板。Features
  • High-speed pipelined 8051-compatible microcontroller core (up to 25 MIPS)
  • In-system, full-speed, non-intrusive debug interface (on-chip)
  • 10-bit 500 ksps single-ended ADC
  • Precision calibrated 24.5 MHz internal oscillator
  • 16 kB of on-chip Flash memory
  • 512 bytes of on-chip RAM
  • Implemented SMBus/I2C, UART, and SPI serial interfaces
  • Four general-purpose 16-bit timers
  • Capacitive Sense interface with 32 input channels
  • Programmable Counter/Timer Array (PCA)
  • On-chip internal voltage reference
  • On-chip Watchdog timer
  • On-chip Power-On Reset and Supply Monitor
  • On-chip Voltage Comparator
  • 54 general purpose I/O
C8051F700 DEVELOPMENT KIT USER 'S GUIDE.pdf
215.48 KB, 下载次数: 0
GMT+8, 2025-1-13 19:41 , Processed in 0.129021 second(s), 16 queries , MemCache On.
