查看: 310|回复: 0
TCS3414数字彩色光传感器模块
发表于 2015-7-30 09:18:10 | 显示全部楼层 |阅读模式
TCS3404和TCS3414数字彩色光传感器被设计成准确地推导出环境光的色的色度和照度(强度),并提供一个具有16位分辨率的数字输出。该装置包括一个8×2阵列过滤的光电二极管,模拟 - 数字转换器,和控制功能的单芯片CMOS集成电路上。16个光电二极管,4个有红色的过滤器,4个有绿色滤光器,4个有蓝色的过滤器,以及4个无过滤器(清除)。在封装微调能力用先进的专利申请,设备到设备和系统到系统容差可以最小化,允许非常精确的可重复性来实现。Feature:
  • Programmable Interrupt Function with User-Defined Upper and Lower ThresholdSettings
  •  Internal Filter Eliminates Signal Fluctuation Due to AC Lighting Flicker — No ExternalCapacitor Required
  •  In-Package Trim Provides an Easy and Accurate Means to Achieve System-to-System Repeatability
  •  16-Bit Digital Output with I2C at 400 kHz
  •  Programmable Analog Gain and Integration Time Supporting 1,000,000-to-1 Dynamic Range
  •  SYNC Input Synchronizes Integration Cycle to Modulated Light Sources (e.g. PWM)
  •  Operating Temperature Range
    • 40C to 85C (CS Package)
    • 30C to 70C (FN Package)
  •  Operating voltage of 2.7 V to 3.6 V
  •  Available in Both an FN and a CS Package. The CS Package is the Industry’s Smallest Digital RGB Color Sensor
TCS3414 EVM2 Quick Start Guide_1_1.pdf
301.14 KB, 下载次数: 0
TCS3414 EVM2 User's Guide.pdf
247.99 KB, 下载次数: 0
TCS3404_Datasheet.pdf
851.77 KB, 下载次数: 0
GMT+8, 2024-11-25 10:55 , Processed in 0.120044 second(s), 16 queries , MemCache On.
