FTDI UMFT4222EV-B开发模块支持FT4222H高速USB2.0到QuadSPI/I²C桥接IC的原型和开发。设计为小尺寸PCB,UMFT4222EV-B插入标准为宽0.8“的24引脚DIP插座,UMFT4222EV-B的主要功能包括:在SPI模式四倍数据模式下高达28Mbps的数据传输速率;在SPI主模式支持高达4个从选择控制引角,支持单个SPI从机模式下SCK工作频率高达20MHz;厂商的特性包括一次性可编程(OTP)存储器;板载跳线FT4222H配置模式; USB电源配置和VCCIO源选择;真正的3.3V CMOS驱动输出和TTL输入; FTDI的免版税的直接(D2XX)驱动程序,以及板载USB微型B插孔。Features
- Single Hi-Speed USB 2.0 chip (FT4222H) to flexible and configurable SPI/I²C interfaces.
- SPI interface support for Single / Dual / Quad SPI Master Mode with configurable target operating speed.
- Up to 28Mbps data transfer rate in SPI mode with quad data mode.
- Support up to 4 slave selection control pins in SPI master mode.
- Support Single SPI Slave Mode with SCK operating frequency up to 20MHz.
- I²C interface support 7-bits address and fully compatible to v2.1 and v3 specification for I2C Master/Slave Mode with configurable target operating speed for 100kbit/S standard mode, 400kbit/S fast mode 1Mbit/S Fast mode plus and 3.4Mbit/S high speed mode.
- Configurable GPIOs controlled by application software via USB bus
- Fully support USB2.0 suspend/resume and remote wakeup
- Support Battery Charger Detection
- OTP memory inside for USB Vendor ID (VID), Product ID (PID), device serial number, product description string and various other vendor specific data.
- USB Power Configurations; bus-powered and self-powered.
- On board jumper for FT4222H configuration mode, USB power configuration and VCCIO source selection
- Integrated power-on-reset circuit.
- True 3.3V CMOS drive output and TTL input. (operates down to 1.8V with external 1.8V power input to VCCIO)
- Support wide supply voltage range.
- USB2.0 Low operating and suspend current; 68mA (active-typ.) and 375uA (suspend-typ.).
- Configurable I/O pin output drive strength: 4mA (min) and 16mA (max)
- UHCI / OHCI / EHCI / XHCI host controller compatible
- FTDI's royalty-free Direct (D2XX) drivers eliminate the requirement for USB driver development in most cases
- Supplied PCB designed to fit a standard 20.2mm (0.8") wide 24 pin DIP socket. Pins are on a 2.54mm (0.1") pitch.
- On board USB Micro-B receptacle allows module to be connected to a PC.
