查看: 274|回复: 0
BIOMETRIC 生物识别传感器扩展卡
发表于 2015-10-21 13:47:15 | 显示全部楼层 |阅读模式
BIOMETRIC-EXP-EVB 卡为 Silicon Labs 的 Si114x 光学传感器和 Si701x/2x 相对湿度和温度传感器提供了一个便捷的开发和演示平台。 此卡可直接插入 EFM32™ Wonder Gecko 入门套件的扩展针座。将指尖置于 Si1146 传感器上即可测量心率和血氧水平。 此外还提供环境感应数据,如 UV 指数、相对湿度和温度。 可选 HRM-GGG-PS 邮票板通过一根 I2C 电缆与 BIOMETRIC-EXP-EVB 连接,即可穿戴于手腕进行心律监测。Key Features
  • Si7013 Humidity and Temperature Sensor
  • Si1146 Proximity/UV/Ambient Light Sensor capable of monitoring Pulse Rate and SpO2
  • 6-pin ribbon cable connector for attaching a postage stamp board
  • 20-pin expansion header
  • Battery operated with low power optimizations for long battery life
  • Demonstration software source code available
  • USB debug mode allowing HRM and SpO2 samples to be transferred to a PC Windows GUI to visualize pulse signals and to record samples from USB debug mode
  • Easy use through Simplicity Studio
GMT+8, 2025-1-13 15:32 , Processed in 0.115413 second(s), 15 queries , MemCache On.
