查看: 1446|回复: 0
Netduino3 开源平台
发表于 2015-9-30 09:58:50 | 显示全部楼层 |阅读模式
Netduino3提供一个STM32F427VI或STM32F427VG的ARM Cortex-M4微控制器的闪存,1或2MB,和256KB内存。通过Wi-Fi启用版,包括TI的CC3100无线芯片,支持802.11b / g / n的连通性,并支持内置的SSL,WEP和WPA2。该Netduino3包括3 GoBus2.0端口,即插即用组件。 Arduino shields 都支持,包括那些使用ICSPheader pads。Feature
  • STMicro Cortex-M4 168MHz microcontroller
  • Code Storage: up to 1408 KB
  • RAM: 164+ KB
  • 3 GoBus 2.0 ports
  • All 22 digital and analog pins: GPIO
  • Digital pins 0-1: UART 1 RX, TX
  • Digital pins 2-3: UART 2 RX, TX/PWM
  • Digital pins 5-6: PWM, PWM
  • Digital pins 7-8: UART 3 RX, TX (also works as UART 2 RTS, CTS)
  • Digital pins 9-10: PWM, PWM
  • Digital pins 11-13: PWM/MOSI, MISO, SPCK
  • Digital pin SD/SC: SDA/SCL (also works as UART 4 RX, TX)
  • MicroSD Card slot
  • 7.5-12VDC or USB powered
  • 5VDC and 3.3V regulated output voltage
  • 25mA max current per pin
GMT+8, 2025-1-28 04:38 , Processed in 0.102184 second(s), 15 queries , MemCache On.
