查看: 320|回复: 0
PIC32以太网入门开发套
  • 签到天数: 361 天
    发表于 2014-8-7 09:10:37 | 显示全部楼层 |阅读模式
    PIC32以太网入门开发套件包括了用于PIC32系列微控制器网络和USB应用所需的一切条件。其中开发板包括了RJ45连接器、片上调试/编程器、USB主机口以及Micro-B型USB口。The PIC32 Ethernet Starter Kit provides the easiest and lowest cost method to experience 10/100 Ethernet development with PIC32. Combined with Microchip's free TCP/IP software, your project will be running in no time. The PIC32 has an available CAN 2.0b peripheral and USB host/device/OTG.The Ethernet Starter Kit has a form factor and expansion connector that are compatible with other PIC32 Starter Kits.The PIC32 Ethernet Starter Kit runs on Microsoft Windows 2000, Windows XP, Windows Vista, and Windows 7.Features:Write Code
    • Free MPLAB IDE v8.43 or newer
    • Free MPLAB C Compiler for PIC32 with no code size limit
    • Example project files for Ethernet and USB applications
    Program Memory
    • Integrated programmer - all you need is the included USB Cable
    • Program and verify a full 512k image in less than 9 seconds
    Debug
    • Integrated debugger - all you need is the included USB cable
    • Full C source-based debugging in MPLAB IDE
    Execute Code
    • PIC32 running at 80 MHz with 512K Flash, 128K RAM, 8 ch. DMA + 8 ch. DMA dedicated to Ethernet, CAN and USB
    • USB powered board
    • USB and Ethernet connectors, user switches, and LEDs
    Customize
    • Expansion connector enables addition of Microchip's PIC32 expansion boards or create your own
    • Majority of MCU signals are present on the connector [Hirose: FX10A-120P/12-SV1(71)]
    Package Contents:
    • PIC32 Ethernet Starter Board
    • Standard A to mini B cable for debugger
    • Standard A to micro B cable for USB application development
    • Ethernet cable
    PIC32_Starter_Kits_Users_Guide.pdf
    2.19 MB, 下载次数: 0
    PIC32 Ethernet Starter Kit Information Sheet.pdf
    99.17 KB, 下载次数: 0
    PIC32 Ethernet Starter Kit User_s Guide.pdf.pdf
    1.13 MB, 下载次数: 0
    GMT+8, 2025-1-28 23:58 , Processed in 0.110782 second(s), 16 queries , MemCache On.
