查看: 265|回复: 0
MCP19111评估板
  • 签到天数: 361 天
    发表于 2014-8-7 09:11:17 | 显示全部楼层 |阅读模式
    MCP19111评估板用于演示MCP19111器件在宽电压输入和负载范围下的同步降压工作。特性
    • 宽输入电压范围 4.5-32V
    • 集成8位PIC微控制器
    • PWM模式
    • I2C接口
    • 高可配置性如可调模拟补偿、可调开关频率等
    • 集成高边和低边MOSFET驱动
    • 集成电流检测
    • 最少外部元件需求
    The MCP19111 is a digitally-enhanced PWM controller. It combines a pure-analog PWM controller with a supervisory microcontroller making it a fast, cost-effective, and configurable power conversion solution. The MCP19111 is ideal for standard power conversion, LED drivers, and battery charging applications. The MCP19111 Evaluation Board demonstrates how the MCP19111 device operates in a synchronous buck topology over a wide input voltage and load range. Nearly all operational and control system parameters are programmable by utilizing the integrated PIC microcontroller core. MPLAB X IDE can be used in conjunction with a Graphical User Interface (GUI) plug-in to easily configure the MCP19111. Alternatively, the user can program the MCP19111 using their own firmware, tailoring it to their application. The evaluation board contains headers for ICSP™ (In-Circuit Serial Programming™) as well as I2C communication, pull-up and pull-down resistor pads and test point pads on each GPIO pin, and two push buttons for system development.Devices Supported: MCP19111PLEASE NOTE: This kit does NOT contain the hardware programming tool. Please use Microchip’s PICKIT3 (PG164130).Features:
    • Vin range: 5V to 12V
    • Adjustable Vout range: 0.5V to 3.6V
    • Maximum output current: 30A with proper air flow
    • Programming and I2C communication headers
    • Factory programmed to produce 1.8V from 12V source
    • The factory programmed source code is available
    MCP19111 Evaluation Board User's Guide.pdf
    434.62 KB, 下载次数: 0
    MCP19110/11.pdf
    3.66 MB, 下载次数: 0
    MCP19111 - Buck Power Supply, Graphical User Interface User's Guide.pdf
    996.6 KB, 下载次数: 0
    MCP19111 Evaluation Board (ADM00397) Schematics.pdf
    75 KB, 下载次数: 0
    GMT+8, 2025-1-15 17:30 , Processed in 0.106566 second(s), 16 queries , MemCache On.
