查看: 244|回复: 0
PICkit 3 Debug Express
  • 签到天数: 361 天
    发表于 2014-8-7 09:14:01 | 显示全部楼层 |阅读模式
    PICkit 3 针对PIC和dsPIC微控制器的调试/编程器,支持Microchip MPLAB IDE集成开发环境。PICkit 3 Debug Express套件中还包括PIC18F45K20微控制器的演示板和USB连接线。特性:
    • PICKit 3 调试/编程器
    • PIC18F45K20演示板
    相关工具
    • PIC32 Ethernet Starter Kit
    • PIC32 USB Starter Kit II
    • PIC32 I/O Expansion Board
    • chipKIT Uno32 Dev Board
    Microchip’s PICkit 3 In-Circuit Debugger/Programmer uses in-circuit debugging logic incorporated into each chip with Flash memory to provide a low-cost hardware debugger and programmer. In-circuit debugging offers these benefits:
    • Low cost
    • Minimum of additional hardware needed for debug
    • Expensive sockets or adapters are not required
    The PICkit 3 can now also reprogram any PIC microcontroller with a simple push of a button: Find out more about Programmer-To-Go functionNote: The PICkit 3 In-Circuit Debugger/Programmer is NOT a production programmer. It should be used for development purposes only.The MPLAB PICkit 3 allows debugging and programming of PIC® and dsPIC® Flash microcontrollers at a most affordable price point using the powerful graphical user interface of the MPLAB X Integrated Development Environment (IDE). The MPLAB PICkit 3 is connected to the design engineer's PC using a full speed USB interface and can be connected to the target via an Microchip debug (RJ-11) connector (compatible with MPLAB ICD 2, MPLAB ICD 3 and MPLAB REAL ICE). The connector uses two device I/O pins and the reset line to implement in-circuit debugging and In-Circuit Serial Programming™.If you need older software for programming with your PICkit 3, please visit our archives.Header InformationSome 8-, 14- and 18-pin devices use small header boards with a special MCU for debugging. This special MCU has extra pins for PICkit 3 communication and therefore allows the use of all pins on the part for the application. The header board is not used or needed for programming. However, when debugging these devices the header must be used. See the "Header Specification" document below.Features
    • USB (Full speed 12 Mbits/s interface to host PC)
    • Real-time execution
    • MPLAB IDE compatible (free copy included)
    • Built-in over-voltage/short circuit monitor
    • Firmware upgradeable from PC/web download
    • Totally enclosed
    • Supports low voltage to 2.0 volts (2.0v to 6.0v range)
    • Diagnostic LEDs (power, busy, error)
    • Read/write program and data memory of microcontroller
    • Erase of program memory space with verification
    • Freeze-peripherals at breakpoint
    • Program up to 512K byte flash with the Programmer-to-Go
    • Header Information
    Some 8-, 14- and 18-pin devices use small header boards with a special MCU for debugging. This special MCU has extra pins for PICkit 3 communication and therefore allows the use of all pins on the part for the application. The header board is not used or needed for programming. However, when debugging these devices the header must be used. See the "Header Specification" document below.DV164131 PICkit 3 Debug Express includes:
    • PICkit 3 Debugger/Programmer
    • 44-pin demo board with a PIC18F45k20 microcontroller
    • All hookup cables
    • a CDROM
    • PICkit 3 User’s Guide
    • A series of 12 Lessons on C programming that cover I/O, A/D converters, timers, interrupts, and data tables (All source code files are provided)
    • A Debugging Tutorial on using the PICkit 3 as a debugger with the MPLAB IDE
    • HI-TECH C PRO for PIC10/12/16 MCU Family in Lite mode.
    • Microchip’s MPLAB IDE software for a complete code development environment
    MPLAB® ICD 3 In-Circuit Debugger User’s Guide For MPLAB X IDE.pdf
    1.08 MB, 下载次数: 1
    Microchip-DV164131-datasheet.pdf
    90.91 KB, 下载次数: 1
    Processor Extension Pak and Header Specification.pdf
    1.22 MB, 下载次数: 1
    Transition Socket Specification.pdf
    688.69 KB, 下载次数: 1
    ETN 32 PICkit 3 Operation at Low Voltage - Modification.pdf
    132.01 KB, 下载次数: 1
    GMT+8, 2025-1-15 17:49 , Processed in 0.108988 second(s), 16 queries , MemCache On.
