查看: 270|回复: 0
Wi-Fi PICtail Plus子卡
  • 签到天数: 361 天
    发表于 2014-8-7 09:15:26 | 显示全部楼层 |阅读模式
    Wi-Fi PICtail Plus子卡是用于评估PIC微控制器和MRF24WB0MA模块Wi-Fi连接性能的演示板。可以通过PIC I/O 扩展板与很多Microchip入门开发板连接。特性
    • 支持IEEE 802.11 b/g/n
    • 支持低功耗、低数据传输
    • 集成PCB天线
    • 4线SPI接口
    • WEP, WPA-PSK, WPA2-PSK
    • 36 pin 表面贴装模块
    相关板卡
    • PIC32 I/O Expansion Board
    The Wi-Fi PICtail/PICtail Plus Daughter Board is a demonstration board for evaluating Wi-Fi connectivity using PIC microcontrollers and the MRF24WB0MA module. This product is compatible with the Explorer 16 Development Board (DM240001), PICDEM.net2 Development Board (DM163024) and PIC32 Starter Kit (DM320001) with I/O Expansion Board (DM320002).Features
    • Supports low-power, low data-rate
    • Wi-Fi FCC (USA), IC (Canada), ETSI (Europe) Certified
    • Integrated PCB Antenna with Simple four-wire SPI interface to PIC® microcontroller
    • WEP, WPA-PSK, WPA2-PSK Security
    Package Contents
    • MRF24WB0MA Wi-Fi PICtail/PICtail Plus Daughter Board
    • Information Sheet
    Quick Guide to Microchip Development Tools.pdf
    7.21 MB, 下载次数: 0
    MRF24WB0MA PICtail_PICtail Plus Daughter Board Information Sheet.pdf.pdf
    47.64 KB, 下载次数: 0
    AC164136ReferenceDesign-Rev4-windows-installer.zip
    4.03 MB, 下载次数: 0
    GMT+8, 2025-1-15 17:43 , Processed in 0.107475 second(s), 16 queries , MemCache On.
