查看: 151|回复: 0
MAX10 Odyssay board
发表于 2015-12-14 11:20:12 | 显示全部楼层 |阅读模式
业界首款 集合 ALTERA FPGA, 蓝牙 4.0 BLE, 环境传感器, 与智能手机应用 的开发套件。Whether you are collecting and processing data, controlling a remove device, or just adding extra hardware processing to an industrial or IoT design, MAX 10 FPGAs offer outstanding value and have the features and capability you need to achieve your design goals.Explore the advantages of Altera MAX 10 FPGAs! The Mpression Odyssey MAX 10 FPGA evaluation kit is ideal for doing proof-of-concept experiments using this Bluetooth SMART enabled development platform.
  • Uses a non-volatile Altera MAX 10 FPGA
  • Full access to all MAX 10 FPGA features, including:
    • Dual-configuration: MAX 10 FPGAs provide a single-on-die Flash memory that supports dual-configuration, for true fail-safe upgrades.
    • Analog Blocks: Integrated analog blocks feature a temperature-sensing diode and an analog-to-digital converter (ADC).
    • Instant-on: MAX 10 FPGAs can be the first usable device on a system board to control bring-up of high-density FPGAs, ASICs, ASSPs, and processors.
    • DSP blocks: As a non-volatile FPGA with DSP, MAX 10 FPGAs are ideal for high-performance, high-precision DSP applications.
  • Access to powerful soft IP such as the NIOS II 32-bit embedded processor
  • DIP form factor with Arduino shield expansion compatibility
  • Microphone, LEDs and switches for user input and output
  • Sensor expansion through I2C compatible interface
GMT+8, 2025-1-13 11:02 , Processed in 0.111999 second(s), 15 queries , MemCache On.
