查看: 307|回复: 0
MAX 10 DECA Board
发表于 2015-12-14 13:48:46 | 显示全部楼层 |阅读模式
DECA MAX 10包括了各种FPGA至传感器/外设连接,例如,加速度计、温度/湿度/姿势传感器、音频输入、LED,以及几种用于扩展的连接器。与Arrow兼容的子卡包括BLE/WIFI BeagleBone兼容小卡和8M像素MIPI摄像头模组。       The DECA Development Kit presents a robust hardware design platform built around the Altera MAX 10 FPGA, which is the industry’s first single ch ip, non-volatile programmable logic devices (PLDs) to integrate the optimal set of system components. Users can now leverage the power of tremendous re-configurability paired with a high-performance, low-power FPGA system. Providing internally stored dual images with self-configuration, comprehensive design protection features, integrated ADCs and hardware to implement the Nios II 32-bit microcontroller IP, MAX10 devices are ideal solution for system management, I/O expansion, communication control planes, industrial, automotive and consumer applications. The DECA development board is equipped with high-speed DDR3 memory, video and audio capabilities, Ethernet networking, and much more that promise  many exciting applications.
The following hardware is provided on the board:
  • Altera MAX® 10 10M50DAF484C6G device
  • USB-Blaster II onboard for programming; JTAG Mode
  • 512MB DDR3 SDRAM (16-bit data bus)
  • 64MB QSPI Flash
  • Micro SD card socket
  • Two CapSense buttons
  • Two push-buttons
  • Two slide switches
  • Eight blue user LEDs
  • Three 50MHz clock sources from the clock generator
  • 24-bit CD-quality audio CODEC with line-in, line-out jacks
  • HDMI TX, incorporates HDM v1.4 features, including 3D video supporting
  • One 10/100 Mbps Ethernet PHY with RJ45 connector
  • One USB 2.0 PHY with mini-USB type AB connector
  • One MIPI connector interface supports camera module application
  • One proximity/ambient lighter sensor
  • One humidity and temperature sensor
  • One temperature sensor
  • One accelerometer
  • Two MAX 10 FPGA ADC SMA inputs
 更多资料<<
GMT+8, 2025-1-13 10:46 , Processed in 0.108980 second(s), 15 queries , MemCache On.
