ADIS16223/ PCBZ是一个“接口板”,它提供ADIS16223CMLZ和接口PCB简化原型的过程在期间系统的设计和评估的早期阶段。该ADIS16223CMLZ是一个完全集成,振动测量/分析系统,它提供了所有的数字通信的串行外设接口(SPI)。它提供了一个灵活的连接器接口,带有一个双行,14针连接器。接口PCB提供了访问ADIS16223CMLZ,使用支持标准的带状电缆系统和手工焊接连接技术的双行的2mm间距,16针连接器。接口PCB提供的安装孔为ADIS16223CMLZ附着,使用10-32机器螺钉。它也提供了一组孔,用于安装接口板到系统的框架,以及另一组排列起来M2x0.4mm抽头上ADISUSBZ评价系统板的通孔的孔。Feature:
- Tri-axial vibration sensing: ±70 g range
- Wide bandwidth: 14 kHz
- Programmable digital filters, low-pass/band-pass options
- Data capture function
- 3-channels, 1024 samples each, 72.9 kSPS sample rate
- Capture modes for managing machine life
- Manual: early baseline characterization/validation
- Automatic: periodic check for midlife performance shifts
- Event: end-of-life monitoring for critical conditions
- Extended: triple the record length for a single axis
- Digital temperature, power supply measurements
- Programmable operation and control
- Capture mode and sample rate
- I/O: data ready, alarm, capture trigger, general-purpose
- Four alarm settings with threshold limits
- Digitally activated self-test
- SPI-compatible serial interface
- Serial number and device ID
- Single-supply operation: 3.15 V to 3.6 V
- Operating temperature range: −40°C to +125°C
- 15 mm × 15 mm × 15 mm package with flexible connector
