查看: 223|回复: 0
TMDSHVMTRPFCKIT开发套件
  • 签到天数: 361 天
    发表于 2014-4-22 15:04:43 | 显示全部楼层 |阅读模式
    TMDSHVMTRPFCKIT开发套件为高电压电机控制和PFC开发者套件提供了简便,用开源的方式来评估短笛或德尔菲诺微控制器,在TI模拟高电压环境下工作。The High Voltage Motor Control and PFC Developer's Kit provides and easy, open source way to evaluate the Piccolo or Delfino microcontroller and TI analog in a high voltage environment. A single MCU controls the power factor correction(PFC) stage and the motor control stage. The PFC takes a line level AC input (~110 to ~240VAC) and outputs up to 750 watts of power, regulated by closed loop control. The motor driver stage can be driven from either the PFC or from a separate power stage and accepts up to 400V and outputs up to 1.5 kilo-watt of power. The motor driver stage can drive the most common types of three phase motors; AC induction, brushless DC, and permanent magnet synchronous motors. The microcontroller controls each type of motor using closed loop control (Trapezoidal, V/F, or FOC) using sensored and sensorless back-emf techniques.Features
    • Support for three brushless motor types, AC Induction, Permanent Magnet Synchronous Motor, Brushless DC Motor
    • Can be used by both Piccolo and Delfino F2833x devices
    • 1.5 KiloWatt motor driver stage
    • 750W power factor correction stage
    • Full source software for power factor correction stage
    • Full source software for control of all three motor types
    • Library based software for latest software observer and high frequency injection initial position detection techniques
    • Piccolo F28035 and Delfino F28335 controlCARD
    • Full source hardware, including schematics, BOM, and gerber files
    • Motors of each type available directly from TI.
    TMS320F28030-35.pdf
    1.5 MB, 下载次数: 0
    controlSUITE™ Software Brochure.pdf
    744.57 KB, 下载次数: 0
    GMT+8, 2025-1-15 17:41 , Processed in 0.116328 second(s), 16 queries , MemCache On.
