查看: 296|回复: 0
DS34RT5110-EVKC演示套件
  • 签到天数: 361 天
    发表于 2014-4-22 14:45:04 | 显示全部楼层 |阅读模式
    DS34RT5110-EVKC CAT5线缆,扩展演示套件提供了具有成本效益的CAT5电缆一个完整的HDMI系统扩展的解决方案,采用了德州仪器的DS34RT5110 - 一个DVI,HDMI重定时器的输入均衡和输出去加重。The DS34RT5110-EVKC CAT5 Cable Extender Demo Kit provides a complete HDMI system extension solution with cost effective CAT5 cables, using the Texas Instruments DS34RT5110 - a DVI, HDMI retimer with input equalization and output de-emphasis. The kit consists of following boards for different application needs: • a DS34RT5110 driver board with HDMI-in and RJ45-out connectors – Board ID: 551600199-034 • a DS34RT5110 repeat board with RJ45-in and RJ45-out connectors – Board ID: 551600199-014 • a DS34RT5110 receiver board with RJ45-in and HDMI-out connectors – Board ID: 551600199-024 • a passive adapter board with RJ45 and HDMI connectors – Board ID 980013178。
    DS34RT5110.pdf
    5.56 MB, 下载次数: 0
    DS34RT5110-EVKC User's Guide.pdf.pdf
    855.68 KB, 下载次数: 0
    GMT+8, 2025-1-15 17:26 , Processed in 0.110588 second(s), 16 queries , MemCache On.
