查看: 289|回复: 0
FPD-Link评估套件
  • 签到天数: 361 天
    发表于 2014-4-17 14:36:05 | 显示全部楼层 |阅读模式
    FPD-Link的评估套件包含一个发射器(Tx)的板,一个接收器(RX)电路板以及接口电缆。该套件将展示来自测试设备或使用低电压差分信号(LVDS)到接收器板上的图形控制器接口的芯片组。DescriptionFPD-Link evaluation kit contains a Transmitter (Tx) board, a Receiver (Rx) board along with interfacing cables. This kit will demonstrate the chipsets interfacing from test equipment or a graphics controller using Low Voltage Differential Signaling (LVDS) to a receiver board.The Transmitter board accepts LVTTL/LVCMOS RGB signals from the graphics controller along with the clock signal. The LVDS Transmitter converts the LVTTL/LVCMOS parallel lines into four serialized LVDS data pairs plus a LVDS clock. The serial data streams toggle at 3.5 times the clock rate.The Receiver board accepts the LVDS serialized data streams plus clock and converts the data back into parallel LVTTL/LVCMOS RGB signals and clock for the panel timing controller.
    FLINK3V8BT-85 User Manual.pdf
    281.97 KB, 下载次数: 0
    GMT+8, 2025-1-15 17:44 , Processed in 0.119996 second(s), 16 queries , MemCache On.
