查看: 327|回复: 0
MINISAS4X演示套件
  • 签到天数: 361 天
    发表于 2014-4-17 13:53:39 | 显示全部楼层 |阅读模式
    DS64BR401EVK - miniSAS4X网线延长器演示套件提供了使用TI的DS64BR401一个完整的电缆延伸方案 - 四路双向有线/背板扩展器,具有均衡和去加重。DescriptionThe DS64BR401EVK - miniSAS4X cable extender demonstration kit provides a complete cable extension solution using TI's DS64BR401 - Quad Bi-directional Cable/Backplane Extender with Equalization and De-emphasis.MiniSAS4X right angle I-PASS Molex receptacle connectors are used as the input and the output connections for SATA/SAS disk drive storage application. Adaptor board which provides connection from mini SAS4X (26-pin external) to mini SAS4Xi (36-pin internal) is provided to allow easy straight forward connection to existing hardware.Features
    • Quad lane bi-directional transceiver up to 6.4 Gbps rate
    • Signal conditioning on input and output for extended reach
    • Adjustable receive equalization up to +33 dB gain
    • Adjustable transmit de-emphasis up to −12 dB
    • Adjustable transmit VOD (600 mVp-p to 1200 mVp-p)
    • <0.25 UI of residual DJ at 6.4 Gbps with 40" FR4 trace
    • Automatic de-emphasis scaling based on rate detect
    • SATA/SAS: OOB signal pass-through, <3 ns (typ) envelope distortion
    • Adjustable electrical IDLE detect threshold
    • Low power (100 mW/channel), per-channel power down
    • Programmable via pin selection or SMBus interface
    • Single supply operation at 2.5V 5%
    • >6 kV HBM ESD Rating
    • 3.3V LVCMOS input tolerant for SMBus interface
    • High speed signal flow-thru pinout package: 54-pin LLP (10 mm x 5.5 mm)
    DS64BR401.pdf
    4.65 MB, 下载次数: 0
    DS64BR401EVK User Guide.pdf
    3.31 MB, 下载次数: 0
    GMT+8, 2025-1-29 00:00 , Processed in 0.118464 second(s), 16 queries , MemCache On.
