查看: 286|回复: 0
CLINK3V48BT-112演示套件
  • 签到天数: 361 天
    发表于 2014-4-8 15:57:25 | 显示全部楼层 |阅读模式
    CLINK3V48BT-112演示套件包含一个发射器(Tx)演示板和一个接收器(Rx)的演示板以及接口电缆。该套件将展示芯片传输数据流通过电缆采用低电压差分信号(LVDS)在七次输入时钟速率。DescriptionThis Channel Link demo kit contains a transmitter (Tx) demo board and a receiver (Rx) demo board along with an interface cable. This kit will demonstrate the chipsets transmitting data streams using Low Voltage Differential Signaling (LVDS) through a cable at seven times the input clock rate.The transmitter board accepts 3V TTL/CMOS data signals from an incoming data source along with the clock signal. The LVDS transmitter converts the TTL/CMOS parallel lines into serialized LVDS pairs. The serial data streams toggle at 7 times the clock speed.The receiver board accepts the LVDS serialized data (and clock) and converts them back into parallel 3V TTL/CMOS data out signals.
    DS90CR483/484.pdf
    1.58 MB, 下载次数: 0
    DS90CR481/482.pdf
    1.61 MB, 下载次数: 0
    CLINK3V48BT-112 Manual.pdf
    550.88 KB, 下载次数: 0
    GMT+8, 2025-1-28 23:52 , Processed in 0.119238 second(s), 16 queries , MemCache On.
