查看: 330|回复: 0
LV04EVK01评估套件
  • 签到天数: 361 天
    发表于 2014-4-2 16:44:24 | 显示全部楼层 |阅读模式
    LV04EVK01是一个评估套件旨在展示性能和DS92LV0421和DS92LV0422通道链路II erializer/解串器芯片组的能力。DescriptionThe LV04EVK01 is an evaluation kit designed to demonstrate performance and capabilities of the DS92LV0421 and DS92LV0422 Channel Link II Serializer/Deserializer chipset.The DS92LV0421 serializer board accepts LVDS input signals and provides a single serialized Channel Link II CML data pair as an output. The DS92LV0422 deserializer board accepts the CML serialized data stream and converts the data back into parallel LVDS signals. A USB cable is provided as a generic medium for the high speed data link. Jumpers and switches on the boards can be configured for evaluation of chipset features such as pre-emphasis, equalization, SSCG and backward compatibility. An I2C interface provides an alternative method to configure features of the serializer and deserializer.FeaturesContents:
    • One serializer board with the DS92LV0421
    • One deserializer board with the DS92LV0422
    • One 2-meter USB 2.0 Hi-SPEED cable assembly
    • Evaluation kit documentation
    What the user needs to provide
    • A 24-bit data bus and clock source with LVDS outputs - for example a video generator
    • A data error checker or display with LVDS inputs - for example an LCD panel and interface from the deserializer board to the panel itself, or test equipment
    • Power supply for both boards
    DS92LV0421-22.pdf
    1.04 MB, 下载次数: 0
    LV04EVK01 Eval Board.pdf
    47.84 KB, 下载次数: 0
    GMT+8, 2025-1-15 17:49 , Processed in 0.112921 second(s), 16 queries , MemCache On.
