TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
AFE5801EVM评估模块有效评估AFE5801的性能。该AFE5801包括一个8通道的电压控制放大器(VCA)与数字控制和一个8通道65MSPS类比至数位转换器(ADC)。The AFE5801 includes an 8-channel Voltage-Controlled-Amplifier (VCA) with digital control and an 8-channel 65MSPS analog-to-digital converter (ADC). The 8 analog input signals will be processed by the analog front-end circuit of AFE5801; the outputs of the analog front-end will then be digitalized by the ADC within the device. In order to process the sample data the Texas Instruments' TSW1250EVM is recommended. The TSW1250EVM includes a High-Speed LVDS Deserializer, Demultiplexer, and Analysis System which provide a comprehensive set of hardware and user interface software to effectively evaluate the performance of AFE5801. Features
- Provide 8-channel low-voltage differential signal (LVDS) outputs from the ADC
- Compatible to the standard TI LVDS deserializer TSW1250EVM
- Communicate with PC through USB interface
- Power Management provides multiple power supplies for AFE5801 and other devices
