查看: 197|回复: 0
LMK01000评估板
  • 签到天数: 361 天
    发表于 2014-3-31 17:28:56 | 显示全部楼层 |阅读模式
    LMK01000评估板简化了LMK010001.6 GHz高性能时钟缓冲器,分频器和分销商的评价。该软件包包括一个评估板,评估板说明,并通过PC并口编程器电缆。DescriptionThe LMK01000 Evaluation Kit simplifies evaluation of the LMK01000 1.6 GHz High Performance Clock Buffer, Divider, and Distributor. The package consists of an Evaluation Board, Evaluation Board Instructions, and a cable for programming the device through a PC parallel port. CodeLoader 4 is the software used to program the evaluation board. CodeLoader 4 will run on a Windows 2000 or Windows XP PC. The latest version of CodeLoader can be downloaded from TI's website. This evaluation kit is also recommended for the evaluation of the LMK01010 and LMK01020.
    LMK01000_10_20.pdf
    519.58 KB, 下载次数: 0
    LMK01000 Eval Brd Operating Instructions.pdf
    829.14 KB, 下载次数: 0
    GMT+8, 2024-11-25 18:22 , Processed in 0.126399 second(s), 16 queries , MemCache On.
