查看: 239|回复: 0
TRF3761评估模块
  • 签到天数: 361 天
    发表于 2014-3-31 16:54:13 | 显示全部楼层 |阅读模式
    TRF3761评估模块(EVM)是设计来评估TRF3761低噪声整数N分频PLL频率合成器集成VCO的性能的EVM工具。DescriptionThe TRF3761EVM is an EVM tool that is designed to evaluate the performance of the TRF3761 Low Noise Integer N PLL Frequency Synthesizer with Integrated VCO. The TRF3761EVM is a fully populated and tested EVM with a mounted TRF3761-E device. The TRF3761-E operates with output frequency ranges of: 1805 MHz - 1936 MHz (Div1 mode), 902.5 MHz - 968 MHz (Div2 mode), and 451.25 MHz - 484 MHz (Div4 mode).
    TRF3761.pdf
    2.04 MB, 下载次数: 0
    TRF3761 EVM Guide.pdf
    984.16 KB, 下载次数: 0
    GMT+8, 2024-11-25 18:51 , Processed in 0.112595 second(s), 16 queries , MemCache On.
