查看: 232|回复: 0
DS90UR907Q-EVK评估套件
  • 签到天数: 361 天
    发表于 2014-3-31 16:21:23 | 显示全部楼层 |阅读模式
    DS90UR907Q-EVK转换FPD链接到FPD-Link。它转换四路LVDS数据/控制流和一个LVDS时钟对成过一对高速串行接口。它是运行向下并兼容老一代的解串器。The DS90UR907Q-EVK converts FPD-link to FPD-Link II. It translates four LVDS data/control streams and one LVDS clock pair into a high-speed serialized interface over a single pair. It is backward compatible for operation with older generationdeserializer devices.The DS90UR907Q-EVK board has a space saving 20-position wall header as the FPD-Link input, and a Rosenberger Automotive HSD Connector as the output. USB or SMA connectors can also be configured as the output, based on the type of the cable to be used.
    DS90UR907Q.pdf
    915.47 KB, 下载次数: 0
    DS90UR907Q-EVK.pdf
    256.75 KB, 下载次数: 0
    GMT+8, 2024-11-25 18:30 , Processed in 0.116675 second(s), 16 queries , MemCache On.
