查看: 539|回复: 0
AFE5809评估模块
  • 签到天数: 361 天
    发表于 2014-3-31 15:24:57 | 显示全部楼层 |阅读模式
    AFE5809评估模块是基于AFE5809进行评估。该AFE5809不仅是高端系统合适的超声波模拟前端的解决方案,同时也为便携式系统。DescriptionThe AFE5809 is a highly integrated Analog Front-End (AFE) solution specifically designed for ultrasound systems in which high performance and small size are required. The AFE5809 integrates a complete time-gain-control (TGC) imaging path and a continuous wave Doppler (CWD) path. It also enables users to select one of various power/noise combinations to optimize system performance. Therefore, the AFE5809 is a suitable ultrasound analog front end solution not only for high-end systems, but also for portable systems.Features
    • 8-Channel Complete Analog Front-End
    • Programmable Gain Low-Noise Amplifier (LNA)
    • 40 dB Low Noise Voltage Controlled Attenuator
    • 24/30 dB Programmable Gain Amplifier
    • 14-bit Analog to Digital Converter
    AFE5809.pdf
    1.72 MB, 下载次数: 0
    GMT+8, 2024-11-25 18:43 , Processed in 0.108628 second(s), 16 queries , MemCache On.
