查看: 187|回复: 0
LMH2191评估板
  • 签到天数: 361 天
    发表于 2014-3-27 16:22:26 | 显示全部楼层 |阅读模式
    LMH2191评估板被设计为具有在评价各种配置的LMH2191最大的灵活性。The LMH2191 evaluation board is designed to have maximum flexibility in evaluating the LMH2191 in various configurations. The schematic, Bill of material and board layout can be found at the end of this application report. In the following sections, a description is given on how the circuit works and how to setup the measurement bench. For the factory default jumper setting, refer to Section 3.
    LMH2191.pdf
    869.15 KB, 下载次数: 0
    LMH2191 Eval. Board AppNote.pdf
    2.57 MB, 下载次数: 0
    GMT+8, 2024-11-25 18:19 , Processed in 0.115693 second(s), 16 queries , MemCache On.
