TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
DS34RT5110-EVKH HDMI线延长器演示套件提供了使用TI的DS34RT5110一个完整的HDMI系统扩展的解决方案 - 一个DVI,HDMI与重定时器输入均衡和输出去加重。DescriptionThe DS34RT5110-EVKH HDMI Cable Extender Demo Kit provides a complete HDMI system extension solution using TI's DS34RT5110 - a DVI, HDMI Retimer with Input Equalization and Output De-Emphasis.Two HDMI female connectors are used as the input and the output connections for a HDMI system.The DDC signals are connected through an I2C buffer.The Hot Plug, 5V Power and 5V Ground are directly connected between the HDMI connectors, making this demo kit HDCP compliant.A 3.3V VCC 1-pin header (J22) and a GND 1-pin header (J23) are used for the power supply.Alternately, an AC/DC power adapter (>800mA) is required for the evaluation kit to provide 5V DC voltage for easy portability. A 1.8mm DC Power Jack is used to connect the AC/DC Power Adapter. TI's LP3965, a 3.3V, 1500mA, Fast, Ultra Low Dropout Linear Regulator, converts the 5V power supply voltage to a 3.3V power supply voltage that powers the DS34RT5110.Features
- Compatible with DTV Resolutions 480i, 480p, 720i, 720p, 1080i, and 1080p with 8 bit, 12 bit and 16 bit deep color depths.
- Compatible with Computer Resolutions of VGA, SVGA, XGA, SXGA, UXGA
- Supports TMDS HDMI Single Link
- Adjustable rotary switches for easy custom EQ boost level setting and De-Emphasis setting to reach maximum length of TMDS Interface with Twisted Pair, HDMI, or DVI Cables
- Single 3.3V Supply
- Ultra Portable with AC/DC Power Adapter (not included in the kit)
- 8kV ESD Rating
- 0 to 70C Temperature Range
Applications:
---Digital Routers---HDMI / DVI Extender Hubs
---Video Cards---Blu-ray DVD Players---Game Consoles
---High Definition Displays---Projectors |
