查看: 172|回复: 0
DS10CP152EVK评估套件
  • 签到天数: 361 天
    发表于 2014-3-26 13:52:06 | 显示全部楼层 |阅读模式
    DS10CP152EVK是一个评估套件专为展示DS10CP152的性能,1.5 Gbps的LVDS的2x2交叉点开关。该评估套件包括与其相关的输入和输出的SMA连接器和跳线手动配置交换机的DS10CP152的。The DS10CP152EVK is an evaluation kit designed for demonstrating performance of the DS10CP152, a 1.5 Gbps 2x2 LVDS Crosspoint Switch. The evaluation kit is comprised of the DS10CP152 with its associated input and output SMA connectors and jumpers to manually configure the switch. The purpose of this document is to familiarize the user with the DS10CP152EVK, to suggest test setup procedures and instrumentation to test the device optimally, and to guide the user through some typical measurements that demonstrate the performance of the DS10CP152 in typical applications.
    DS10CP152.pdf
    760.71 KB, 下载次数: 0
    DS10CP152EVK Manual.pdf
    1.11 MB, 下载次数: 0
    GMT+8, 2025-1-15 20:49 , Processed in 0.113932 second(s), 16 queries , MemCache On.
