查看: 399|回复: 0
CDCLVD2102评估模块
  • 签到天数: 361 天
    发表于 2014-3-25 14:24:11 | 显示全部楼层 |阅读模式
    CDCLVD2102评估模块(EVM)旨在展示CDCLVD1204或CDCLVD2102的电气性能。该CDCLVD1204/CDCLVD2102是高性能,低附加抖动时钟缓冲器。该器件还具有片上偏置发生器,可以提供LVDS共模电压的设备投入。DescriptionThe CDCLVD1204/CDCLVD2102 are high-performance, low-additive jitter clock buffers. They have two universal input buffers that support single-ended or differential clock inputs and are selectable through a control pin (for CDCLVD1204 only). The devices also feature on-chip bias generators that can provide the LVDS common-mode voltage to the device inputs. The evaluation module (EVM) is designed to demonstrate the electrical performance of the CDCLVD1204 or CDCLVD2102. However, this EVM can also be used for customers interested in the CDCLVD1208 or CDCLVD2104 as well. This fully assembled and factory-tested evaluation board allows complete validation of device functionalities. For optimum performance, the board is equipped with SMA connectors and well-controlled 50-ohm impedance microstrip transmission lines.Features
    • Easy-to-use evaluation board to fan out low-phase noise clocks
    • Easy device setup
    • Fast configuration
    • Control pins configurable through jumpers
    • Board powered at 2.5 V
    • Single-ended or differential input clocks
    • Device supports four LVDS outputs, EVM supports two LVDS outputs
    CDCLVD2102.pdf
    914.21 KB, 下载次数: 0
    CDCLVD1204_2102 User Guide.pdf
    210.89 KB, 下载次数: 0
    GMT+8, 2025-1-15 22:11 , Processed in 0.102127 second(s), 16 queries , MemCache On.
