查看: 430|回复: 0
打印 上一主题 下一主题
CDCLVC1112评估模块
  • 签到天数: 361 天
    跳转到指定楼层
    楼主
    发表于 2014-3-24 16:31:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    CDCLVC1112评估模块(EVM)旨在展示CDCLVC1112的电气性能。该CDCLVC1112是一款高性能,低附加相位噪声的LVCMOS时钟缓冲器。它有一个LVCMOS输入和12路LVCMOS输出。它也有一个使能引脚。DescriptionThe CDCLVC1112 is a high-performance, low additive phase noise LVCMOS clock buffer. It has one LVCMOS input and twelve LVCMOS outputs. It has also an enable pin. This evaluation module (EVM) is designed to demonstrate the electrical performance of the CDCLVC1112. However, this EVM can also be used for customers interested in evaluating the performance of the CDCLVC1106, CDCLVC1108 or CDCLVC1110 as well. For optimum performance, the board is equipped with 50-ohm SMA connectors and well controlled 50-ohm impedance microstrip transmission lines. Features
    • Easy-to-use evaluation board to fan out low phase noise LVCMOS clock signals
    • Easy device setup
    • Enable pin configurable though jumper and SMA
    • Board powered at 3.3V
    CDCLVC11xx.pdf
    901.35 KB, 下载次数: 0
    CDCLVC1112EVM User Guide.pdf
    83.21 KB, 下载次数: 0
    举报
    站长推荐上一条 3/4 下一条
    【¥150积分】2025英飞凌创新大会—分论坛机器人:智驭未来
    大会会在深圳和北京巡回进行,上午是主论坛,下午将有多个分论坛同步进行,本次活动我们将会聚焦下午分论坛的机器人主题,聚焦英飞凌如何助力机器人高速发展、氮化镓解决方案在机器人中的应用、MCU驱动机器人的进化之路等等精彩主题分享,此外还有茶歇和幸运抽奖。
    查看 »
    GMT+8, 2025-3-23 18:42 , Processed in 0.103010 second(s), 18 queries , MemCache On.
